How do I do a draft post so that I can save it and then come back to it later before posting to the forums?
There isn't a draft option for the forums. You might wish to consider Notepad?regards,
Duncan Brown
Duncan Brown said:Notepad
Notepad is not good, because it has not spellchecker ;-)
Personally when I know my answer will be long or will require several versions, I usually use OneNote (that I use daily anyway) or Word.
Jan
Labyrinth Technology | dev.notes() | cad.point
