I have a membership pending for the developer network, anyone from Bentley that could give a hand to grant access?
Hi Luc Poulin,
I see you just submitted a request for assistance today (Fri 3/8/2019 11:52 AM) and I will raise your issue to the BDN program owner to reach out to your for your needs and suggestions. I presume someone will likely be in touch with you about accessing the SDK on Monday.
Thank you,Bob
I would just like to have you confirm proper access now. Your use of the BDN Contact Us Form allowed Swarnila Sett to identify that you did not have a necessary GUID registered and she states that this should now be corrected. Could you please check and let us know if the issue is resolved, or continue following up on the BDN Contact Us Form to help ensure your prompt access is provided/restored in the most timely manner possible?
Thank you and HTH,Bob
Hi Robert
I can see the BDN content, will explore today/this week ( with my developer(s)) and let you know.
Thank you for your help, well appreciate
Have a good day /week
Gone through the BDN, but could not find any info
Beside having access to the BDN , here what I was looking for ( take from the web side)
«.....The SDK consists of several “C” libraries that are referenced into your Microsoft Visual Studio project to create Windows applications, console applications, custom modules, and services. The SDK also includes focused support for web based applications.....»
