I have a membership pending for the developer network, anyone from Bentley that could give a hand to grant access?
If I understand correctly, Luc, you are look for a way to download Bentley SDKs. I would think the SDKs can only be accessed via Software Download area, which you would need a Bentley subscription of some sort to have access to. Probably best to post a request in BDN forum to see if someone from Bentley can give you a specific download link to the SDK that you want.
The above is in assumption that you haven't got any subscription in place with Bentley. If you already have a subscription that allows software download from Bentley, you should be able to download SDKs through the usual process.
Best regards,
Tuan Le
Hi Tuan
That is exact, about the download I'm looking for. We have subscription to Bentley download but so far could not find it, I can give another try.
Any suggestions what I should search for?
Basically we wanted to automate task in ProjectWise and create bridges between several application we have. We have start looking at the PowerShell but we fell we can do more using the SDK. Or at least wanted to explorer what the SDK offer
Hi Luc,
Luc Poulin said:We have subscription to Bentley download but so far could not find it
to download (any) product SDK, you have to:
Luc Poulin said:Any suggestions what I should search for?
There is not special "SDK category", SDK for a particular product is listed together with the product itself:
With regards,
Jan
