Is it possible for me to change my login email?
If it's not possible for me to change it I would like it to be changed to:
joshua.whealy@watermanaspen.co.uk
Josh
Hello Josh,
It appears that your Bentley Communities email address is already set to joshua.whealy@watermanaspen.co.uk. However, when you sign in, you use your single-sign-on (SSO) Bentley login, which is linked to your Communities email address. I see that your linked Bentley account seems to be using a different email address (ending in ...mann.com).
If you have changed companies and would like to retain your Bentley Communities activity and transfer it over, please have your company's Site Administrator create an account for you (joshua.whealy@watermanaspen.co.uk), then let me know here (or private message by hovering over my name and choosing the Send Private Message option) and I will ensure that your Communities account is properly connected. That way you will be able to sign in with the new desired email address and still see your old activity/settings on Bentley Communities.
Hi again, I am having trouble accessing my old communities account. I am writing this from a new account my employer has set up for me. Please could a forum admin send me a PM to help me sort this out.
