Why is the Federation to Communities different to CONNECT Center and other cloud services from Bentley?
Hello Neil, this is currently the expected behavior; signing into the CONNECT Center will not automatically sign you into Bentley Communities. There are technical reasons for this due to the way that sign-in is implemented on Bentley Communities. It is possible that this may change in the future.
