Dear Bentley Communities,
I am using MicroStation V8i series3, for Saudi Aramco projects with Auto-SACS tools & I am facing the problem when I am editing the tile block info with Auto-SACS tools as mention below.
1) When I am changing title block information, drawing title in the Auto-SACS data entry and run process.
2) After running the process Auto-SACS default colors setting is not appearing, it's changing to another color, for example, red color, it should not be.
3) Auto-SACS default colors setting for example 2, 7, 61, & 63.
find the Sample image below for your reference.
I would like to know how can I resolve this to default Auto-SACS color setting, Is this MicroStation error or any kind of bug, etc.
Mansoor
Hello Mansoor, this is a forum for feedback on the Bentley Communities site, not for product support. For product technical questions, please post on the forum within the respective product community.
With that said, I am not familiar with "Auto-SACS", so I did some searches and came across this post, which seems to indicate that this is not software by Bentley but rather a third party add-on to MicroStation.
If this is indeed a MicroStation question, you can post on the MicroStation forum. If this is a SACS question, you can post on the SACS Forum. Or, I can move this post if needed.
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
It appears answers have been provided in the MicroStation forum that this Auto-Sacs tool is a 3rd party application and support for it should be requested from Aramco.
https://communities.bentley.com/products/microstation/f/microstation-forum/189994/auto-sacs-default-colors-setting-is-not-appearing
