Dear All,
Can we assign custom Keyboard shortcut in STAAD Pro. for the options like "Select Node", Select Member" etc in the menu.?
Any help will be highly appreciated.
Thanks alot.
Apologies Syed, I missed the Staad reference.
is it for STAAD Pro. ?
So Bear any idea about STAAD if it has Custom keyboard shortcut assign option?
STAAD.Pro is having a long list of predefined shortcuts. You can see that going in the help file in below link.
C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\Help\GUID-8E9DAF27-0814-4E8E-94D2-F1204A222EDD.html
Apart from that there is no way to define new short cuts. But you can place the necessary icons in quick access toolbar and in quick access commands. Please see below link.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/37793/customizing-the-interface-in-staad-pro-connect-edition
