https://translate.google.it/?hl=it
Buongiorno da quando mi ritiro mi piacerebbe rimanere in contatto con la community di bentley, quindi vorrei modificare l'email di accesso in "callegher.massimo@alice.it" Grazie
Hello Massimo,
I have changed your email address as requested. Please confirm that you are still able to sign in and use Bentley Communities without a problem.
In italiano:
Ho cambiato il tuo indirizzo e-mail come richiesto. Conferma di essere ancora in grado di accedere e utilizzare Bentley Communities senza problemi.
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
Hi Jesse I saw that your email has successfully arrived at the new address. but I can't access the community. Rightly so? can I see without logging in? Thank you
I add message
Massimo, in the far upper-right corner (when signed in), you will see a button to view your private message. There may be a red "1" next to it. This is where you can view the message I sent you.
I had changed your Communities profile email address to the personal email address, but the other parts of your Bentley account still use the old email address, which *may* cause a problem. However if you can sign in (with your work email address) and view and post content on Bentley communities (and get emails on your personal address), then you should be all set.
If you need to be able to sign in with your personal email address as well, please create a new Bentley account with your personal email address here: https://ims.bentley.com/IMS/Registration Then, let me know and I will connect your existing Bentley Communities account with the Bentley account that also has the same, personal email address.
Hello at the top right I have no new private messages I read message in the new address, if I try to create a new account it tells me it is already now I try to delete my account from the necessary addresses of the company, maybe we will resend tomorrow here is night now thank you so much
