Dear,
How can I see how many badges did I earn till now?
Hi Ivan, you can see this in your profile. Click your avatar icon in the far upper-right corner and choose "Profile", then click the Achievements tab. Here is a shortcut for your list:
https://communities.bentley.com/members/c149c64e_2d00_9fa2_2d00_437c_2d00_a2c1_2d00_dd8c9ce95afb/achievements
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
Thank you for the reply.
Still I am not able to see the stars, only the number of points and posts.
Hi Ivan, the star-based badges begin when you have accumulated at least 1000 points. I see that you do have just over 1000 points though and did not receive the Bronze (two stars) badge. I believe I have fixed the problem - please try posting another reply, which should trigger you to receive the badge.
Dear Jesse,
Let's try again. Could you check it now?
Thanks. There will be a delay before the task runs to assign badges. I will check back periodically and keep you updated.
