Hi bentley,
i'm a student and learning about mechanical design. As i was studying, i had a question, so i left it like this.
<situation>
Some company is using ASME as a standard. But client's request is JIS.
In this case, what are the countermeasures?
THANK YOU
Kim,
Which Bentley product are you using? (AutoPIPE? RAM? STAAD? OpenPlant?) You have posted in the Communities Feedback Forum which is intended for questions about the use of this site itself. Your post will need to be moved to the appropriate product community forum where a specialist can assist.
