Userway accesability widget
Recently, it appears that you have enabled userway accesability on this site. This causes a large widget to pop up on a small android device and blocks out important content on a small screen. The widget has a hide option but it does not accept the hide indefinitely command and reappears the next time I access the site. It is quite irritating. I have also noticed that the site locks up occasionaly on load which started happening at the same time the widget appeared. Is there a way to disable this?
Here is an example of how it blocks content in the website
