I'm not seeing any type of Activity from the BE Communities Home page when logged in.
I have started using Chrone not logged in just so that I can see what new posts are being posted. Doesn't seem quite right somehow!
We are seeing the same thing... it is being looked into.
Phil,
You say that this is fixed as of today. How do I get this to work as I'm still not seeing anything list on the Home page when logged in?
stuartw said: Is it just me who doesn't have this working?
That is a good question... all the testing that we have done so far indicates this is working fine. So additional details (i.e. did you customize your homepage, etc.) would be good to know to help us try to figure out why you are not seeing what we are.
stuartw said: When is it going to be fixed?
Assuming we get a scenario that reproduces what you are seeing, then we can provide suggestions, ideas, etc.
Unknown said: Is it just me who doesn't have this working?
I've removed the tags list from the home page, that's all. If I revert to the defaut settings it appears to work!!
BTW it doesn't work with Firefox which I haven't touched. I'm using Firefox, not signed in, to see the new activity.
Edit. I reverted back to default, logged out and then in again. I then removed the tags list using cutomise, and the activity is still showing. All appears to be OK. I guess it was the tags widgit that was causing the proble. Thanks for bearing with me:-)
Unknown said: I was wrong, when the "SITE ACTIVITY" widget "Activity List Mode" is set to "Dashboard (all site activity)" I see some activity. When it is set to "Group" or "User Profile" I don't see any activity (not sure how to use these settings).
Does anyone know how to use the Group or User Profile settings? This is where I would like to see a couple additional options (Subscribed & Favorites) to show only the posts (including all Blogs, Forums, Groups & Wikis) which the user has Subscribed or marked as a Favorite.
Thanks - Roy
Ideally I would like to see two tiers of tabs / filters to control this "SITE ACTIVITY" widget for Subscribed or Favorites:
First tier:All, Blog, Forums, Groups, Media & Wiki
Second tier:All, Recent, Unanswered, Unread & Your Discussions
If I had this type of control I think I could easilly filter and quickly access most of the content I need for the site.
- Roy
Is there an answer to this? Or are these settings which do NOTHING?
Zstar Electronic Co.Ltd, Sell fire cards for DS/NDSL/NDSi, also have Wii, DSiLL, NDSi, NDSL, PSP2000, PSP3000, PS2, PS3, PSPgo, PSP, Xbox360 accessories, all kinds of phones are available
www.zstar.hk
www.tigersupermall.com
