I'm not seeing any type of Activity from the BE Communities Home page when logged in.
I have started using Chrone not logged in just so that I can see what new posts are being posted. Doesn't seem quite right somehow!
Stuart,
The "SITE ACTIVITY" or "Activity Message List" widget on the home page is not working at all. If you use the "MY STUFF" widget you should see your own activity displaying. I am not sure about the "RSS Feed" widget or other dynamic tools.
I was wrong, when the "SITE ACTIVITY" widget "Activity List Mode" is set to "Dashboard (all site activity)" I see some activity. When it is set to "Group" or "User Profile" I don't see any activity (not sure how to use these settings).
Just tried this at home and I'm still not seeing any listings on the Home page when logged in!!
Is it just me who doesn't have this working? When is it going to be fixed?
stuartw said: Is it just me who doesn't have this working?
That is a good question... all the testing that we have done so far indicates this is working fine. So additional details (i.e. did you customize your homepage, etc.) would be good to know to help us try to figure out why you are not seeing what we are.
stuartw said: When is it going to be fixed?
Assuming we get a scenario that reproduces what you are seeing, then we can provide suggestions, ideas, etc.
Unknown said: Is it just me who doesn't have this working?
I've removed the tags list from the home page, that's all. If I revert to the defaut settings it appears to work!!
BTW it doesn't work with Firefox which I haven't touched. I'm using Firefox, not signed in, to see the new activity.
Edit. I reverted back to default, logged out and then in again. I then removed the tags list using cutomise, and the activity is still showing. All appears to be OK. I guess it was the tags widgit that was causing the proble. Thanks for bearing with me:-)
