Currently, there are a number of places where Bentley Developer Network subscribers and third-party developers who use MDL, native code, or VBA to create customizations with MicroStation-based products can go to get answers to development questions. These include:
The number of choices has led to some confusion as to where to post inquiries, and since communities exist for context-specific topics (e.g. MicroStation Visualization, ProjectWise Programming, Geospatial Programming, etc.), it makes sense to have a “MicroStation Programming” community and rationalize the various options into one. There is existing content that has some value, so to retain that while starting anew, this is what is being proposed:
It is anticipated that all this can be done in a relatively short amount of time -- maybe an hour or two, at most. We are looking at doing this over the June 16/17 weekend. We just wanted to provide some advance notice of this upcoming activity.
This maintenance is now done. The following forums:
are archived in read-only mode, meaning you cannot create new threads or post replies to previous threads in them (however, you can still search them to find information from past discussions). Topics originally intended for any of those forums should now be posted in the most applicable community forum identified below:
MicroStation Programming: For discussions, ideas, and other information about developing with MicroStation development tools, any MicroStation SDK, and MicroStation VBA.
ProjectWise Programming: For discussions, ideas, and other information about developing with any ProjectWise API or SDK.
Geospatial Programming: For discussions, ideas, and other information about developing with any Geospatial API, SDK, and toolkit.
Before starting a new thread, please refer to the MicroStation Programming forum best practices. Also, please include the following in your post:
You are not required to be a Be Communities member to read public postings, but you do have to be a member and signed in to start a new thread or reply to an existing one.
If you are not currently a Be Communities member, joining is easy -- see Getting Started for more information regarding this. After you join and sign in, edit your profile and then start connecting with others in your profession.
Should you have any questions specifically regarding Be Communities, please post those in the Be Communities Feedback Forum. If you encounter any difficulties with joining or signing in, please let us know.
Is there an updated version to this? when i click the MicroStation Programming link i get a message that the page cant be found
Steven, here is the Programming homepage: https://communities.bentley.com/products/programming/
Here is the MicroStation Programming community: https://communities.bentley.com/products/programming/microstation_programming/
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
