Migrated Be Communities Search functionality
Once the Be Communities migration has completed its first phase, you will recognize more prominence and improvements to the site’s search. The search field will be located closer to “the action” on the home page as well on the pages within each community. Search context (i.e. the current application/area/community or across the entire site) will also be more obvious.
The results page is also significantly better… faceted navigation is included, providing the ability to narrow or expand based on application (e.g. forum, wiki, etc.), author, post date, tags, etc. You can also sort by relevance (the default), most recent article/post, alphabetical order, or rating. Navigating from one “page” of results to another is also much easier.
We will be using tags quite a bit more than previously for “Support Solutions” (aka wiki) articles. This will help “tie” solutions for products OR product areas together across the site.
