Being Slammed with email Automatic Emails for the last couple of days
Please find a way to stop them.
Example below:
The following thread was moved:
Subject: Auto Updating DimStyles and Textstyles from DGNLIB
Moved to: MicroStation - Forum
You were sent this email because you opted to receive email notifications for this forum or thread. You can view this thread online.
To unsubscribe from only this thread, disable email notifications online. To disable all email notifications from Be Communities by Bentley, navigate to "Settings", click on the "Email" tab, then under the "Email Configuration" section, set "Send Notifications" to "No".
Roland Cyr
  • We are in the process of moving threads from the MicroStation Annotations community forums to the MicroStation community forums (to consolidate that community... part of a "community clean-up" that we have been mentioning for a while). If you are receiving notifications of that, there could be a few things activated. I did notice that you had subscriptions set up for some of the MicroStation forums, so those were disabled. You may have to disable more (at least while these things are being moved). We did not know that this would get through the subscription notices, so we will look for ways to prevent that before we move around other community forums.
