New location for the FileFormats Community
The FileFormats community will be moved in its entirety over the weekend of June 28-29. We anticipate a brief outage in that community -- at most a few minutes, but all existing content (e.g. forum threads) should persist through to the new location -- basically right under the Products community, to help provide a place for non-DGN File Format inquiries across all Bentley products. If you are following this community or community forum through the Communities' bookmarks, those should automatically update. If you have these locations bookmarked in an browser you are using, those bookmarks will need to be updated after the move is complete.
We appreciate in advance your patience and understanding while we work on making Communities better.
  • This has now been completed. Basically what was done was move:
    communities.bentley.com/products/microstation/microstation_interoperability/...
    to
    communities.bentley.com/products/interoperability/...
    Any Web browser bookmarks should be updated to point to the new community (although we do recommend using the site's bookmark function instead, as that takes these sorts of moves into account a whole lot easier). Should you encounter a URL that has /products/microstation/microstation_interoperability/ in it, you can safely remove the microstation/microstation part and the URL should resolve.
