Error in the values of support reactions in print preview report.
Dear all,
             I'm using Stadd Pro V8i SS6 and new to the use of this software.After analysis when I move to the report setup and then from  there selecting the  output I try to select the reactions for printing.Now the problem arises here where the vertical axial values(FY) which exceeds 1000 comes with a 'E". For e.g If the value is 1228.042 KN it appears as 1.23E+3. Can anyone please help me sort it out...
Plaban
