Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Security.Cryptography.CryptographicException: Key not valid for use in specified state.Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[CryptographicException: Key not valid for use in specified state. ] System.Security.Cryptography.ProtectedData.Unprotect(Byte[] encryptedData, Byte[] optionalEntropy, DataProtectionScope scope) +407 System.IdentityModel.ProtectedDataCookieTransform.Decode(Byte[] encoded) +64 [InvalidOperationException: ID1073: A CryptographicException occurred when attempting to decrypt the cookie using the ProtectedData API (see inner exception for details). If you are using IIS 7.5, this could be due to the loadUserProfile setting on the Application Pool being set to false. ] System.IdentityModel.ProtectedDataCookieTransform.Decode(Byte[] encoded) +320 System.IdentityModel.Tokens.SessionSecurityTokenHandler.ApplyTransforms(Byte[] cookie, Boolean outbound) +177 System.IdentityModel.Tokens.SessionSecurityTokenHandler.ReadToken(XmlReader reader, SecurityTokenResolver tokenResolver) +737 System.IdentityModel.Tokens.SessionSecurityTokenHandler.ReadToken(Byte[] token, SecurityTokenResolver tokenResolver) +83 System.IdentityModel.Services.SessionAuthenticationModule.ReadSessionTokenFromCookie(Byte[] sessionCookie) +508 System.IdentityModel.Services.SessionAuthenticationModule.TryReadSessionTokenFromCookie(SessionSecurityToken& sessionToken) +164 System.IdentityModel.Services.SessionAuthenticationModule.OnAuthenticateRequest(Object sender, EventArgs eventArgs) +146 Bentley.Framework.Authentication.WsSessionAuthenticationModule.OnAuthenticateRequest(Object sender, EventArgs eventArgs) +183 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +160 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +115
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34274
