In the QuickStart for Building Designers Using MicroStation learning path, all the download links for each component courses are pointed to the same zip file containing:
Converting the Building Quickstart from feet and inches to Metric.pdf
Text Drawing Scales and Sheet Sizes for Feet- Inch to Metric.pdf
Which are not related to any of the courses in that learning path. If this can be fixed, it would be greatly appreciated.
Best regards,
Tuan
Tuan,
You should see two ZIP files contained within that main file that you downloaded:
You then have to choose one of the two QuickStart zip files inside the original zip file to get to the PDFs for the courses. The two PDFs at the top level are provided to help if someone wants to work with both the Imperial and metric units. Once you select one of the QuickStart zip files, you should see:
Please let us know if this helps.
