i am using microstation connect edition..... and i cant find the example files....there are worksets for metrostation...but the ones shown in training videos are not present......what to do ?
Hello Mahim Khan,
Do you mean Learn Server videos? In Learn Server you can download dataset with example files and documentation, e.g. here:
http://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=109367
When you extract the zip file there are for example these files:
I hope this helps!
Kind regards,Anu
I know this ..... but for this lesson "Microstation everything 3D" I can't find dgn files
If you scroll up a little you will see the following, I believe these are the files your looking to download
Carl Myhill
Technical Support Engineer
Bentley Systems
It sounds like you are talking about the old Example Projects provided in MicroStation V8i and that you have now installed MicroStation CONNECT Edition. This latest release only contains the example project called Metrostation but you should be able to locate these old workspaces from the Bentley Library via the following link.
https://communities.bentley.com/communities/other_communities/bentley_library/m/library
Exactlyyyyyyyy......... tysm
