I am planning to create (or use pre-defined) learning path(s) for MicroStation v8i. there will be saperate learning paths for new users, basic users and advanced users.
System currently provides certificate at the end of each module or set of modules. Is it possible for Bentley Institute to provide an assesment for new, basic and advanced MicroStation v8i user? So, users must take the assesment after finishing the modules, if they want to be provided with a certificate.
Do we currently have any modules/learning paths regarding MicroStation v8i that requires an assesment at the end?
Baris Cansever
Hi Baris:
Learning Units are granted when the instructor turns in the roster and the roster is processed. They are not affected by the completion of an assessment. We have many MicroStation courses that have an assessment, but the student can choose to take or not take the assessment.
We do not have a mechanism to require the assessment. And even if the student chooses to take the assessment, we do not maintain a record of the grade (pass/fail, greater than 70%, etc.). HTH
Teresa Rosher
Thank you Teresa.
How about reports? I believe we can export report for users.
Can we also have a report per user to see how many modules (and which modules) that individual user has completed?
Hello Baris,
If you are an admin on your account you can access Learn reports under the admin section in the Learn Server.
Danielle
Hi Danielle,
Thanks for the response.
I'm hoping to be an Admin soon, that's why I'm trying to find out a bit more.
