Setting up an Organizational Learning Path
So after searching this issue I have seen others (from years ago) with the same question but no actual answer in the thread.
When I go to set up an organizational learning path (I have admin rights) I just see that I have none setup, there is no "Create" or anything of the sort. When I go to the help section to see how to use the these features, the section with where I assume articles should be I just get a spinning wheel. Nothing ever loads.
Any insight would be appreciated!
Chris
