I am trying to follow "Bentley Connect Advisor>Learn>QuickStart for MicroStation CONNECT Edition for Existing Users> but got stuck at "Creating the Workspace"
There is no exercises zip folder in C:\BentleyCONNECTTraining\. All the folders and subfolders “Standards” “WorkSets” are empty. It looks like I need to download something missing.
Please help
Hi Oktay,
The exercise zip folder is available under QuickStart for MicroStation CONNECT Edition for existing user practice workbook (hands-on) in the LEARNSERVER. See image below
if you click in download you can save them locally
You should see the following after unzipping the folder:
Similar if you use the CONNECT ADVISOR. See image below
if you select Practice workbook you can download the zip file
Maria
Dear Maria
Thank you for your response, most appreciated. But I still cannot find webpage link for the zip file to download. I tried multiple version of searches with "QuickStart for MicroStation CONNECT Edition for existing user practice workbook (hands-on) in the LEARNSERVER" but got nowhere. could you please let me have the website link for the zip file download?
Also, your images appear to be a little low resolution and I am unable to read even with enlarging the images. If I cannot work out all the steps you have described, at the next stage, I might ask for a better resolution images, if you do not mind.
Oktay
Answer Verified By: Oktay Karel
Karan Sharma - Product Engineer - Bentley Systems advised the link as https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=109567&mcId=102060 - Thanks Karan.
Beware: The link didnt work. He advised the link may not work with Firefox. Worked with Chrome to open but not working now, assuming pandemic is starving data flow?
