QuickStart for Point Clouds using Bentley Pointools Full Course
This course will show you how to use Bentley Pointools V8i to handle point cloud data. Point Clouds are created by laser scanners and produce a point wherever the laser hits, allow you to map out a 3D volume. Since millions of points are needed these files can be large and hard to process. Bentley Pointools V8i is optimized to give performance even to the most challenging data. Point Clouds give us existing information allowing for planning, environmental impact, clash detection, design and extraction of data, plus much more.
24 Apr 2015 9:00 AM - 12:00 PM EDT 3 hrs Robert Bossler
Gina Mazzulla said:This course will show you how to use Bentley Pointools V8i to handle point cloud data. Point Clouds are created by laser scanners and produce a point wherever the laser hits, allow you to map out a 3D volume. Since millions of points are needed these files can be large and hard to process. Bentley Pointools V8i is optimized to give performance even to the most challenging data. Point Clouds give us existing information allowing for planning, environmental impact, clash detection, design and extraction of data, plus much more.
Is there any other course like this ?
