So I am extremely new to Microstation as well as Descartes so this has been a rough transition from AutoCad and any and all help here would be wonderful.
I have a pipe that I am trying to model by section from a point cloud. I have created my section and am trying to setup a template to use as I walk forward. While learning the basic fundamentals of this process I have contacted the bentley support and they resourced me to a video of a woman giving instructions on how to do this process, however, in her video she uses a B-spline curve to create the template. I, on the other hand have a known diameter pipe and would like to use a circle for the template. I have drawn the circle using the base geometry tool and when I go to select it for my template it says it is not valid for the tool. I understand that the problem here is almost slapping me in the face but I find it rediculous that the program would only allow for splines to be used as a template.
Any and all help with a solution or to understand why this is would be greatly appreciated.
