Hi Bentley,
We're running a simulation project so that all models have to export to OBJ file for editing in 3DSMax. However the exported files made by a large number of polygons (Img.: roughly 200,000 faces for a street corner) , then it's maybe impossible if we have to build larger areas.
By any way If your Software can adjust the acurate amount of faces (polygons) of exported 3D models ? Or if it doesn't, do you have any suggestion about third softwares that have retopologize tools for 3D models ?
Thanks.
Hi Jan,
Thanks for your reply, I forgot to mention about the software. Now we are using Bentley ContextCapture Master and aerial data from UAV to create 3D models ( for our navy simulator project ). As I said, OBJ. files production have too much polys (faces) and our problem is decreasing the number of polys(faces) as much as possible for editing in 3DsMax.
Here's our latest model, it's quite amazing but it's too hard for our Simulator software if we want to expand the captured area.Any suggestion will be appriciated.
Hi Nguyen,
Here a screenshot as requested:
Hi Felix,
In our Navy simulator project, we have to simulate the large riverside area last over 2 districts. Because of the large amout of images so I had to create 2 models of each district ( 2 seperate files that have different default SRS coordinates origin) . Because Merging process requested 2 parts must have the same SRS." , so I adjust "SRSOrigin" of both descriptions to the same number (in notepad++), and at .3mx file, these two overlap each other. (image no.3)
So Is it possible to merge 2 files with different SRSorigin ? Or Are there any things else that I have to config in production submiting time ?
If you haven't already do this, you might try setting the Geometric Simplification mode to Planar. When you make a new Reconstruction it is on the Processing Settings tab. Since much of the surfaces you are capturing are planar this should help reduce the number of facets in the final meshes.
Regards,Ron
