Dear Felix, Ben,
In order to import recent FLS (faro scan format) with POD Creator, I have followed the procedure you’ve described in the Bentley Communities.
The update DLL procedure works well for Bentley Descartes & Microstation.
However it doesn’t work with POD Creator (we still get “failed” message when importing FLS).
Could you please have a look to this issue and tell me how to fix that ? Please understand that PODCreator is really suitable for batch conversion.
In attachment I send you the bat (32bits for PODCreator ; 64bits for Pointools).
PS: The direct FLS to POD export in FARO Scene soft doesn’t work well. There are remaining significant misalignments between scans. It is obvious that it is a bug from FARO. We have double checked that with a 3rd soft. That’s the reason why FLS import is the only reliable solution to get exact scan adjustments from FARO Scene process.
Antoine BILLAULT
Answer Verified By: Antoine Billault
