I need to re-color a bunch (100s) of LAZ point clouds based on matching ortho photos (probably ECW) and I don't know how to achieve this. I have access to microStation, Descartes and poinTools.
1. How do I re-color a bunch of point clouds using ortho photos?
I imagine the process to be something like: Import all the clouds and ortho photos and press a magic button that makes each XY-point (effectively ignoring the point clouds Z-coordinate) grab the color from the proper pixel from the ortho photo image sharing that XY-space.
1b. Should I convert from LAZ to POD using poinTools for Descartes? Descartes does not import LAZ point clouds. poinTools lists the importing as possible in the latest error-fix update, but lacks any tools to re-color them?poinTools can probably convert them to POD though.Oh, bonus question, lucky you:
2. Is there a way to thicken a pointcloud using an existing Bentley software solution?
I need this for animation purposes, and these particualr clouds are sort of thin. But it would be perfectly okay to add interpolated points between the existing points. I think the cloud is basically a XY-map with heights added, so the math would even be pretty simple.
2b. Assuming no, can I hack at it in VBA?
Regards,Torben
