[SS3] Point Clouds and data conversion
I have converted numerous .LAS files into .POD files. I saw, during the conversion process, the option to assign a coordinate system for the output .POD file, which I did not do. Now that I have the .POD files, is there any way to bulk/batch assign the projection info to the .POD files, or will I have to go and re-convert the .LAS files again, this time assigning the projection info as well? Can Pointools be used to assign the coordinate information?
Bruce
