Dear All,
We need to produce very long animation from MMS lidar survey (eg. 100 km of railway survey).
We also need to display CAD texts onto pointcloud during that animation (eg. mile marker, catenary number, etc...).
On the Communities, there are many posts and former answers explaining that Pointools is not dedicated to CAD, ie doesn't support very well CAD features. Indeed when we import Text from Microstation , then text orientation is lost and is displayed in 2D, not in 3D (see screenshot below).
We tried another solution : converting text into 3D extude text (=3D parametric model). Then we export that text into OBJ and try to display it into Pointcloud. Here many issues happened either in Microstation & Pointools.
Let me detail these issues step by step:
Issue 01 :It appears that Microstation doesn't explode text into constant feature. you get letter/number either as complex plane shape (ok for extruding) or as hole ? (impossible to extrude) >> see screenshot attached for an example.
Issue 02 : impossible to extrude all these feature in a batch. You need to extrude each feature one by one, so forget about it if you have thousand of text to convert in 3D.
Issue 03: when you export your text convert into 3D parametric shape into OBJ , the obj file is corrupted. A simple QA-QC with Meshlab returns nothing... Here again I stress a Bentley interoperability issue between Pointools & Microstation (2 Bentley softs ! ...why DGN is not handled ?). Obj format is the only 3D format in common between the 2 soft, but Microstation Obj output seems not to work well on basic 3D parametric object such as text...
WOuld you please comment that post and give me your expertise on these questions ?
antoine
Felix,
Have you tried applying a thickness and exporting to OBJ?
=>> Yes i did.
there is still sometimes weird...
Here is what I have got in Pointools
You can clearly noticed a PB with the location of the text (it should be coordinates in Million => EPSG:3943)
Last but not least, sometimes I have got the text at right location but 3D shape are crumpled
