Could anyone tell we wich parameter to use in Context Capture sensor size
It is a Sony EXMOR 1/2.3” with effective pixels/photosites of 12.4 megapixels (total pixels are 12.76, but all do not get processed in jpeg compression - RAW, I do not know).
The sensor is 6.16mm wide and 4.62mm high.
The maximum created still image size is 4000 pixels wide by 3000 tall on both the Professional and the Advanced.
Also, the field of view is 94°, and it has a 20mm equivalent f2.8 fixed lens.
best regards,
Mark Bos
Answer Verified By: Felix James
Hi Mark,ContextCapture requires the width of the camera sensor.
View online
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum. To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Flag this post as spam/abuse.
If you select a photogroup you should see the "Camera Model Type" field on the right side of the screen. You can click it and select "fisheye" instead of "perspective" if the photos have a lot of barrel distortion.
Hi Felix, Thanks for helping out. I found some information on sensors, is this information correct and can i use the width as input for the sensor size in ContextCapture?
Mark
