I currently have 04.01.00.508 installed and when I go to Help>Check for update it says my version is up-to-date.
When I check on the Bentley Software Fulfillment Center it says there is a newer version 04.01.00.514.
Are these two versions identical?
ContextCapture 04.01.00.514 is not the same as .508. It contains many bug fixes as well as the following new features:
It appears that the "Check for Updates" feature is not working, thanks for reporting, we will investigate this.
Pascal
Hi Pascal,
This is a clip from the change log installed with .508
----------------------------------------------------------------------- ContextCapture v4.1------------------------------------------------------------------------ Fisheye camera support.- New camera database (camera model, user database, user interface).- New user interface to import positions/rotations from text files.- Video frame import. - Aerotriangulation algorithm improvement (frustum, new input data min/max viewing distance, block type nadir).- Texturing improvement (texturing per sub-triangle).- New command line tool to export a unique LOD mesh from a 3D reconstruction composed of several tiles.- Acute3D Web Viewer version 1.1, with improved loading speed
It appears to include the same items you listed for .514 in your post.
Are there any other changes?
Regards,Ron
Answer Verified By: Ron Jones
