Pointools V8i - Cloud disappears when the camera gets close
When I'm viewing my attached POD's, the point cloud disappears when I approach it in the viewport. It appears to be a spherical distance from the point of view of the camera/viewport. I want to create an animation with a very close flyby of small grouping of utilities within the point cloud, but the points are not visible at the distance I want to view them at. appears to be an issue with both Explore and Examine.
I have not tried to approximate the key locations and render it to see if only affects the viewport
POD files are created from E57's which were exported from Cyclone.
Data is of a tunnel, and the problem only occurs when the camera gets close any portion of the cloud. I can animate the center of the tunnel with no issue.
Parents Reply Children
