Grid computing - spread workload
Can anyone explain how i can spread my workload across multiple PC's using the grid computing in ContextCapture?
i have multiple computers on the same network (along with all CC jobs) and they all have a full version of CC installed.
I was hoping it would be simple but because i haven't found anything online, i'm starting to doubt that.
Many thanks
RIchard
  • Hi Richard,
    First, you'll need to place your project and images in a shared folder that can be accessed by all computers. You will also need to place the job queue in a shared folder than can be accessed by all machines.
    Then, on each computer that is running an engine, open "ContextCapture Settings" and select the "Configuration" tab. From there, select the job queue shared folder. Exit the dialog and start ContextCapture Engine.
    Finally, on the computer where the project is located, open ContextCapture Master. Select the top node in the project tree and select the "Options" tab. Toggle ON the "Use proxy UNC path..." option. And, update the job queue shared folder.
    HTH,
    Pascal
     This is a test
    Answer Verified By: Felix James
  • Thanks for the response Pascal,
    I have followed what you've said and the secondary engine shows up in the job que on the main CC master but when the secondary engine tries to run each pending job it fails after 1 second.
    Hopefully someone has come across this problem before and can offer some advice.
    many thanks
    Richard
  • I would check the engine on the computer running the job that failed and see if it is telling you why it failed. I found when setting up a cluster, the most common problem was making sure that all the files (photos and project file) were shared so that they could be accessed by all the computers in the cluster.
    This is a test
Reply Children
