I downloaded the PointTools creator and viewer software. The POD creator software installed properly bit the Viewer does not. It goes through the process and ended successfully but the application is not installed; there is only one folder in the application directory. I am using an old Windows XP system but this should not really matter as other 32-bit applications work fine.
Has anyone else experienced this problem?
Farouk Rohoman
