[ContentCapture] Optimal use of manual tiepoints?
I have a picture set of a fairly complicated scenario (industrial plant). An AT does not manage to tie all pictures together (a lot of "lost" photos after the AT). I have therefore started to create manual tiepoints to "help" the AT. This seems to help, because after doing this, the number of "lost" photos decrease. Now the question:
When creating manual tiepoints - is it better to create MANY tiepoints with fairly FEW [defined points in pics], or is it better to create a FEW tiepoints with MANY [defined points in pics]?
As it is a bit cumbersome job to add points, it could be good to know which stategy to use when doing this manual job.
Thanks in advance for replies!
