LumenRT is installed and enabled for few programs.
Then new program is installed, and it will not have LumenRT menu.
Do you need to fully re-install LumenRT, so that it would recognize new products? Or there is some configuration setting/utility, which can re-scan programs and enable LumenRT integration?
Hi, the right procedure to install LumenRT on the top of the other software is: first install the software and then install LumenRT. Alternatively if you still have in your pc the lumenRT Setup file, you can run it as administrator and it will install again the software. This works also as "repair option" if LumenRT is corrupted in some part.
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/30007.enable-lumenrt-for-new-installed-software regards Mara
