Lords and Ladies of the forums, I have a few newb questions on LumenRT/Microstation/Vissim.
Has anyone had any issues with exporting a DGN to LumenRT with a Vissim traffic simulation showing up in different locations or none at all? I'm noticing on some of our larger models, we need to break up the DGN elements into separate pieces or nothing will load within LumenRT or a small partial area of the model is exported (even when selecting large model export).
Does anyone know of a tutorial on the Vissim side for use with DGN's as base maps? I'm not a Vissim guy, but the ani.txt file we receive doesn't seem to be working well with Microstation or LumenRT.
On large models, we have had luck exporting an OBJ and importing that into LumenRT. Everything is loaded perfectly, but all the materials have a glass setting instead of standard. It's a bit of a pain, but it would be fantastic if we could change the default.
How has your experience with LumenRT been so far?
Thanks!
And edit/replace NS to 1
