Hi.
I have issues with pointools on my system.
When I go above, or around 1.000.000.000 points - the system gets laggy and I have experienced the loss of lots and lots of work.
So..
Q: Is 16GB of RAM enough for pointools? Q: Is the HDD cache used for anything? (I set it to 50GB, but it seems to be reset to 1GB, and hardly used)Q: Is there a way to get to work with - edit and render smoothly with no errors - 10's of billions of points - at once?
As it is, I need to workaround this by cutting my pointclouds into tiny bits. This makes the process extremely slow and painful..
Any help appreciated.
