We are working in PowerCivil with white background color. When testing Descartes Merge command to create georeferenced rasters, all black (color 0) elements were excluded from the raster.
Is there a setting somewhere that allows me to create a georeferenced raster with white as background color?
I have found a configuration variable named "_DC_TRANSPARENCY", but I have not found any documentation on that variable.
In the example below, only non-black colors are saved to raster.
ORIGINAL
OUTPUT FROM MERGE TOOL
fmcallis, it seems that if I have the background set as white, the elements with color "0" are excluded from the export. This means that inversion is not a solution. Please see the video. Hopefully this makes my issue clearer and that other users can replicate the issue as well.
In the video, I am attaching a raster file just to have access to the merge tool.
Link to video for those of us without flash: https://youtu.be/w3M_nANE8qU
Thomas H. Stavik-KarlsenSenior Engineerhttp://www.Akersolutions.com
Answer Verified By: Thomas Stavik-Karlsen
