Descartes Merge vector with white background
We are working in PowerCivil with white background color. When testing Descartes Merge command to create georeferenced rasters, all black (color 0) elements were excluded from the raster.
Is there a setting somewhere that allows me to create a georeferenced raster with white as background color?
I have found a configuration variable named "_DC_TRANSPARENCY", but I have not found any documentation on that variable.
In the example below, only non-black colors are saved to raster.
ORIGINAL
OUTPUT FROM MERGE TOOL
  • One option that you could do is change the element that was white with a black background that shows black when you change the background to white from 0 to 253, which is a black color. Another option would be to set the color mode to monochrome on your output image rather than RGB.
    You can create your output file as a GeoTIFF or an Internet TIFF or a TIF image with a sister file and it will save the location where the output image is attached.
