Hi there,
Could someone help me with the problem of context capture error? I found an article from the community about change the job queue: http://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/24685.changing-the-jobqueue-directory, but I still get the error message (I have changed the route to C:\Job queue folder that I new build).
What should I do to fix the problem?
Cheers,
Tim
HI, I m also facing a similar issue. After the Task type is listed, the engine is not able to access the queue and profile jobs. Request you to please helpbelow is the window of CC engine:
ContextCapture Center/Evaluation version 10.19.1.45 running << C:\Program Files\Bentley\ContextCapture Center\bin\CCEngine.exe >> from directory << C:\Program Files\Bentley\ContextCapture Center\bin >>[2022-Mar-14 11:17:37 UTC] Starting CCEngine.exe on DELL@carbsews02
=============================================================================Welcome to ContextCapture Center/Evaluation Update 19.1 - v10.19.1.45 (Trial)=============================================================================We detected 1 physical devices.There are total 1 physical devices for application: Device 0: NVIDIA TITAN RTX of NVIDIA: vulkan version 1.3.194, device memory: 24276 MB, host memory: 65384.2 MB
Warning: Expired beta featuresProcessing the following task types: AI AT RasterProduction TileProduction
How do you start the engine manually?
