We get TDR error when Contextcapture is intensively processing TileProduction. Would disabling TDR help or it is driver issue? Does Contextcapture can handle TDR errors or the Tiles should be reprocessed?
OS:Win10 Pro
RAM:64GB
GPU: GTX 980 Ti (driver 369.09)
Can you attach the log for this project in particular ?
The best should to attach the log of the previous version and the log from the latest (even if it still computing) so to be able to compare them and see what's wrong here.
Here's a screenshot that explain how to export a log file from Contextcapture:
Click on the reconstructed production then click on General tab
Now click on <More details> button then Right-click on the tile and choose "Export log file for technical support" option.
Pierre
Here you will find the two logs at this adress: https://we.tl/2iuH8ECcWz
the okay one is te one with correct processing times (launch some months before)
The not ok is the one still processing
Kind regards
