We get TDR error when Contextcapture is intensively processing TileProduction. Would disabling TDR help or it is driver issue? Does Contextcapture can handle TDR errors or the Tiles should be reprocessed?
OS:Win10 Pro
RAM:64GB
GPU: GTX 980 Ti (driver 369.09)
Theses are my results. Semms strange that so few memory of my GPU is used, or ?
Hello Pierre,
Here is the corresponding screenshot :
As you can see, the score is close to yours (117.1).
Concerning the project, I tested on many different blocks that I already processed let say 2 months ago. The blocks varies including photos (24 Mpixels in RAW from Canon 5D Mark III) from 20 to 300 photos per block. Right now for a concrete example, I am running a project (AT done) with 74 photos used for reconstruction, and it is still calculating the 3D reconstruction after more than 12 hours (started yersteday at 8 pm). As a benchmark, I ran the same project on my colleague computer which has a 1080 GTX and 64 Gb of RAM, and it took less than 3h to complete.
I do not split the model before reconstruction nor use for theses blocks the Ultra option.
Any possible leads toward a solution :) ?
Thanks !
Kind regards,
Florent
Ok let's check another thing :)
We suspect the Timeout Detection and Recovery key is not set properly and could impact the performance of the GPU card.
- Could you open regedit then go to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
- Can you tell me if you have a TdrLevel or any other Tdr registry keys that are listed here ?
For example I only have the <TdrLevel> key that is set to (0) which is the value you should have by default.
Best regards,
Pierre
Answer Verified By: Oto
Hum, it seems I have the same value as you stated :
What do you think ?
