I have a .3mx file referenced into a Microstation drawing. In Microstation, I can view the 3mx mesh and images just fine. When I try to use Luxology Rendering or export to LumenRT, the mesh becomes white with no images. What setting am I missing?
Here's a work around:
You can go back into ContextCapture and pick a different Production Format such as OBJ which should work in MicroStation V8i.
Select the Reconstruction that was use to produce the 3MX and click on Submit new production... , then select OBJ in the Format/Options.
It appears that LumenRT is not reading the material assignment of the 3mx. I have tried exporting to LumenRT from Microstation V8i and CONNECT edition with no luck. All I get is a white texture map with no photography. Any suggestions for fixes?
Try latest LumenRT Update1. Also check with CloudCompare(3rd party tool) if the OBJ actually contains the texture.
Hi. Can you help me? after referencing 3mx file into LumenRT there are black window in the Lumen. What can i do?
