Hello. I was curious if the LumenRT 2016 version now available for download will coexist with LumenRT 2015 (specifically in my case the last e-on released update/build). Can I keep 2015 installed, install 2016 simultaneously, and use either one / both without causing problems or loss of use? Is the answer at all specific to plugins, in other words, different answer depending on plugin?
In my case, I'm using SketchUp 2015 currently (will be using 2016 also). I assume others here may have similar question for at least MicroStation as well as potentially other plugins like Revit, etc. Oh, and if there is a product manual and/or installation guide that explains any of this, please advise on where to find. Thank you.
I can confirm both versions can work in the same pc.
Just to remember that only one can be installed on the top of you software by selecting the software through this window:
regards
Mara
Hello Lee,
Where can I download the latest LumenRT version? I was referred to this topic on Autodesk forum. I also found a couple of older links (which are not working btw) on Lumion forums.
@hireessaywriter
