How to export KML which is relative to Google Earth ground? It is either sinked in earth or is above earth. If using Google Earth Pro it is possible to hide Terrain but then model is above earth because of elevation difference.
The heights in Google Earth refer to EGM96 and are, therefore, Geoidal heights. Your model probably uses vertical datum.
You can override the vertical datum of a production in ContextCapture, here is a screen capture that illustrates how to do it:
HTH,
Pascal
