I am working in Bentley map on a point cloud. I am having an issue with the density of the cloud when I zoom in to see specific features. I need to be able to select objects in the cloud and classify and clip them etc. but when I zoom in the point cloud appears less dense than it actually is and objects are difficult to distinguish. I originally thought that I had lost some of the points when the cloud was exported from Agisoft photoscan, however the overall point number is the same, but in Agisoft the cloud appears significantly more detailed than in Bentley map or Bentley Descartes (same issue with both versions). Is there a setting that I can change to improve this? I have included a screen capture from agisoft (bottom) showing a pipe in the point cloud and the same pipe at a similar scale as seen in Bentley (top image).
__
Hello Pascal, It took a while but we were able to make a las file that I could send you. The only problem is that after compression the files is still close to 3 GB. Is there a way that I can get this to you?
