[ContextCapture] LAS export
It seems I cannot export to .LAS file my productions. Here is an example :
I checked the storage space and working space, both > 500 Go free space
The log file is available at this link : https://we.tl/htAagkRtBH
Under Windows 10, version ContextCapture 4.1.0.514
With specs GTX 980, Core i7, 32 Gb RAM
Would you know what seems to be the problem ?
Kind regards,
  • Hi Florent,
    You appear to be using an older version of ContextCapture. Can you please update to the most recent version (currently 4.3.0.507) and try again.
    The log file that you sent was for the aerotriangulation which shows no problems. If you are still having the same problem after you have you have upgraded to the latest version please generate a new log file for the failed production and create a Service Request for technical support.
    You can create your service request by signing in to www.bentley.com and selecting support at the top right of the web page.
